Switching versions
We are currently running Windchill 12.0.2.10 in production with Creo 7.0.10.0. The cache is in a .pdm12 folder under the user's start -in folder on disk. If we run Creo 9.0.5.0 to the same server without making any other changes, we have an issue with switching folders in the workspace. If I dlete the .pdm12 folder and all content, register Windchill in Creo 9, everything works normally. If we then run Creo 7 again, it hoses the cache and Creo 9 will not switch workspace folders until we delete the .pdm12 folder and resgister WIndchill again.
Has anyone else experienced this issue and have a solution? I am not too worried about it, as once we go to a new version, we seldom have need to utilize the older version again. It probably would only be me as the admin who might have a need for an older version of Creo to test something.
