Creo elements 17 stl export "negative space"
  • April 27, 2011
  • 3971 views
Each time I try to export a file as an stl, I get the warning stating that the part is in negative space. No matter where
I position it, the warning persists. I Are there some settings I can adjust to avoid this. Is there an icon that dsiplays the parts XYZ coordinates?
Would you let me use a sample file with that problem to do it some tests? I had no problems yet exporting from PRO/E to .stl to use it in 3D printing, but that negative values alerts... I see it in .dwg to .stl
Can you borrow me some of your files in a post?
Best regards
Faustino Garcia
Hi Faustino,
I have the same problem. Files enclosed.
Kindest Regards
