About ProE Relations
  • March 27, 2010
  • 4131 views
How can I control the material add/remove option by relation in any feature. e.g. if I am adding a rib on the cylinder and I want to control it by relation... I mean to ask, how can we control the Elements of any feature by relation or program edit.
Tarun, I'm a little confused by your question. You mention both Features and "Elements". Do you mean that you want to turn entire features "On and Off" using relations? If so, you may want to investigate using ProPROGRAM (Tools/Program). You can use conditional logic like {IF RIB=="YES" . . . ENDIF} within the Program to do what you want. David
Dear David,I want to control the default element of any feature...for example. I want to control Material should be removed or add for any feature by relations. how can i define this in relation or pro/program.
I mean to ask, Can I control the Materail add or remove by relations? for example, if Cylinder Dia. is greater than 100 mm than add the material else remove the material....
