Batch Office Import
Is there a way to batch import thousands of Word documents into Codebeamer? I understand that the UI is more of a wizard approach with the ability to select a file, set rules, preview, then finally import. But if I want to assume the content is good and use a basic rule (e.g. import all with no conditions) then is there a way to do this?
The back story is that the documents are exported from an old and non-accessible system and Word docs are the only file format available so ReqIF is not an option. Or is this a situation to hire a bunch of interns, show them how to import using the CB UI, then let them loose to import everything?
