Action Required: Changes coming to Vuforia Expert Capture apps and URLs
  • June 5, 2023
  • 2010 views
On July 1st, 2023, Vuforia Expert Capture will be migrated to a new platform. To avoid usage interruptions of Vuforia Expert Capture apps, the following actions need to be taken by July 1st, 2023:
                For more information, see our Help Center topic Network Configuration Requirements.
After July 1st, 2023, previous versions of the Vuforia Capture and Vuforia Vantage apps will no longer work.
3-Newcomer
June 19, 2023
If your Vuforia Expert Capture apps are currently using any URLs for accessing content or services, you will need to update those URLs to align with the new requirements. Ensure that all URLs used in your applications are pointing to the correct locations and follow the updated guidelines.
