Active Directory Integration
  • June 26, 2020
  • 2 replies
  • 1828 views
Can we integrated VEC with the company AD (Active Directory) ?
If no, is it on the roadmap?
Best answer by tmccombie
VEC does support Identity Federation using SAML 2.0. At the moment, a Support ticket is needed to complete this configuration.
Since Capture is a hosted solution, you probably mean Azure Active Directory or generally the support of SAML 2.0 for authentication.
tmccombie21-Topaz IAnswer
