How I can integrate the QR code reader with Vuforia Instruct or Expert Capture?
  • September 15, 2022
  • 1083 views
I want to know how I can integrate a QR code reader in the quality control process with Vuforia Instruct.
For example, at the beginning of the process, I want to read the serial number of the product with the QR code reader, after that, I should have a list of the quality processes of this product with Vuforia Instruct.
Next, I must select an option from the lists and start the QA process with Vuforia Instruct.
hi @Alejandro_Diaz
Setting a procedure to require a serial ID will provide a QR cod reader option when the end user opens the procedure in Vantage. See our Help Center topic on using the QR code scanner for more information.
