How to use JT files?
  • March 12, 2024
  • 1372 views
I want to know, how to import / use JT files in Vuforia editor.
Currently the system response with this error message:
The manual doesn't say very much to this topic.
The JT file was written with Creo 10. (You'll find the files attached and packed)
Thanks in advance
CheerEO
Marco
Best answer by VladimirN
Found the following note on JT-files - "Model Target Generator does not support .jt": https://developer.vuforia.com/forum/model-targets/model-target-generator-does-not-support-jt
VladimirN24-Ruby IIIAnswer
So we (or a customer) needs an additional creo view license plus the JT license to convert JT files into PVZ. Like quoted in the link:
JT file type support is not directly included in the Model Target Generator. Users need to have Creo View and the JT adapter installed on their machine, which requires a separate license.
Would be great if either the documentation would be updated or the format hidden in the open dialog.
