Skip to step function
  • September 20, 2023
  • 0 replies
  • 699 views
Requesting an improvement for Vuforia Expert Capture:
While making instruction videos it would be helpful to be able to have the end users skip directly to certain steps with a method similar to selecting a pass/fail.
This would allow for short, temporarily divergent instructions to be given and followed based on alternative scenarios that the end user might encounter.
Example:
  Step 7: If you have been supplied with an order that requires:
                             'x', proceed to step 8, and follow steps 8-11.
                             'y', proceed to step 12, and follow steps 12-14.
                             'z', proceed to step 15, and follow steps 15-18.
 At steps 11, 14, & 18, verify completion and proceed to step 19, using a selection method similar to the pass/fail already deployed, move the operators view directly to step 19.
