Unable to successfully upload Capture
  • May 14, 2020
  • 2 replies
  • 1993 views
I have tried to upload multiple captures to the VEC server for editing.  Each time (I've create both small and large captures) I receive a message that 1 file failed to upload.  Eventually the capture appears but the steps are all invalid.  I had this working yesterday, now all uploads fail with the 1 file failed to upload message.  Any ideas on what might be causing this?
I have not seen this issue.  I would suggest filing a TS ticket and providing your capture to R&D to investigate.
Can you provide a little more detail - Device - Type and version and maybe the capture zip
ksweeney5-Regular MemberAuthor
This was a couple of months ago.  The problem has not resurfaced since.
