What's New in Vuforia Expert Capture 1.1.25
  • May 28, 2021
  • 0 replies
  • 856 views
Vuforia Capture
  • Bug fixes and minor improvements
Vuforia Editor
  • Ability to require a Vuforia Vantage user to enter a serial ID for an object
    • The serial ID entered will appear as a field in Vuforia Insights and will tie the physical object to a session
  • Ability to require different kinds of feedback for individual steps
Vuforia Vantage
  • Ability to enter a serial ID for an object if required
  • Ability to enter different types of feedback for steps if enabled
    • Confirmation:
    • Pass/Fail:
Vuforia View
  • Procedure playback is no longer supported in Vuforia View for mobile devices and tablets
Vuforia Insights
  • New Serial ID column that displays the serial ID of the object entered by the Vuforia Vantage user
  • New Procedure Status column
    • A procedure session is marked as pass if one or more steps require Pass/Fail feedback and no failures are provided. A session is marked as fail if one or more steps are marked as fail.
  • New filter panel with options to filter by date range and procedure status
