What's New in Vuforia Expert Capture 3.17.0
Vuforia Editor
- Step Check™ Now Supported with Single Part Markers
- Authors can now enable Step Check on steps that contain a single part marker. Step Check, when used with part markers, is view point-aware and can be trained from anywhere that the parts geometry is not occluded. Step Check will be able to detect which angles training images have been collected for, and will only return results for those angles.
For more information, see Enable Step Check for a Procedure in Vuforia Editor and Quickstart: Collect Training Images with Guided Training in Vuforia Vantage.
- Automatic Image Feedback Now Enabled by Default when Pass/Fail with Step Check is Selected
- When a step is set to Pass/Fail with Step Check, Automatic Image Feedback is now enabled by default.
Vuforia Vantage
- iOS
- When a Step Check step has both Auto Proceed and Require Image Feedback enabled, the step will proceed automatically after a pass result is given and the required feedback image has been taken by the user.
- When using multiple part markers, the wayfinder is now only shown if all markers are occluded.
- Android
Bug Fixes
See Bug Fixes for additional information on bugs resolved in this release
