What's New in Vuforia Expert Capture and Vuforia Instruct 3.3.0
  • February 9, 2023
  • 0 replies
  • 1045 views
Vuforia Editor
  • Updates and Improvements to TASKS Page
    • The following updates and improvements have been made to the TASKS page:
      • Approved, Cancelled, Rejected, and Pending candidates are now displayed
      • The following filters are now available for the TASKS table:
        • Filter By Status
        • Filter By Role
      • The USERNAME column now displays the name of the user that created the approval workflow with Submitter next to their name
      • The TIME STAMP column displays:
        • The time and date that the approval workflow was created if the row is for a Submitter
        • The time and date that an assigned approver completed their task
      • The TASKS table is now sorted by TIME STAMP
  • Updates and Improvements to Step Check (Beta)
    • The following updates and improvements have been made to the Step Check functionality:
      • Blurry images captured during training are now automatically discarded before uploading to Vuforia Editor
      • The Step Check Settings section has been moved from the PUBLISH tab to the STEP CHECK tab
      • Improved user experience for START TRAINING action
Vuforia Vantage
  • Improved Voice Commands on RealWear Devices
    • Improvements to voice commands now allows you to easily open favorited and downloaded procedures without having to say the full procedure name
Vuforia Insights
  • Date Filter on AUDIT HISTORY Table Uses UTC
    • The date filter on the AUDIT HISTORY table now uses UTC time.
      • For example, in past releases, if a user is in Central Time zone and logs into Insights at 11:00 am local time, sets a date range of December 4-11, and then clicks Download Report, the cover sheet will show a date range of Dec 4, 2022, 6:00 AM UTC - Dec 12, 2022, 5:59 AM UTC. This was because local time was being used as input and was adjusted based on time zone to reflect the equivalent time in UTC. Now, with this update, a date range of Dec 4, 2022, 12:00 AM UTC - Dec 11, 2022, 11:59 PM UTC will be displayed
Settings
  • Disable/Enable Step Check Setting Now Visible Only to Vuforia Instruct Users
    • The Disable/Enable Step Check setting is only visible to customers with a Vuforia Instruct license, and will no longer be visible to customers with only a Vuforia Expert Capture license
