What's New in Vuforia Expert Capture and Vuforia Instruct 3.5.0
  • April 21, 2023
  • 0 replies
  • 960 views
Vuforia Editor
  • New Step Check (Beta) Mode in Step Check Settings
    • From Step Check Settings on the Step Check tab, you can now select a mode for Step Check. The following modes are available:
      • Setup—this mode enables guided training to help train the step
      • Active—once the step has been trained, switch to Active mode to display the Step Check results in Vuforia Vantage
    • Along with the new modes, you can also select the type of Step Check results that are displayed in Vuforia Vantage, enable or disable data collection, and view the Step Check status of the step. For more information, see Step Check Tab
Vuforia Vantage
  • iOS:
    • The image captured using the iOS Vantage image feedback feature has been improved to around 4k*2k resolution.
  • HoloLens:
    • The images captured using the HoloLens 2 Capture app have been improved to around 1080p resolution.
  • Step card UX/UI has been improved to make it more compact and use less screen space, in addition to including more text by default.
Vuforia Insights
  • Organization Administrators Can Now Control Visible Information in Viewer Insights Table
    • Username, role, and date/time are hidden or limited in the VIEWER INSIGHTS table if the organization administrator has enabled the new Remove User Information from Viewer Insights setting. For more information, see the Settings section below.
Settings
  • New Remove User Information and Dates from Viewer Insights Setting
    • A new setting was added that allows administrators to hide certain information on the VIEWER INSIGHTS table. When this setting is enabled, the following changes occur in Vuforia Insights:
      • USERNAME and ROLE information will be hidden for all Vantage sessions within the VIEWER INSIGHTS table.
      • All date formats will be updated to hide the specific day and time. The new format will only display month and year (for example, Jan 2023).
      • Both of the above changes will be reflected in the VIEWER INSIGHTS table as well as in the exported report.
      • All date range filter selections of less than 7 days will be prevented by the system.
