Javascript quark #1
- June 5, 2019
- 1 reply
- 1068 views
we can do many tricks with Javascript in Studio and most of the times it's just a matter of copying & pasting the right code.
I'd like all Studio users, not just coders, to benefit from this, and thought I could drop here a snippet to blink a widget.
I call this a quark - from the particle physics standard model - and not atom, because it's really a smaller building block than an atom
Blinking a widget can be useful, for example, if you are not using Creo Illustrate to create a sequence but still want to draw the user attention to some item in the scene.
Here's the Javascript code to copy & paste to your Home.js:
(to Javascript coders: I'm using modern Javascript syntax, don't be frightened by that
$scope.blink = function(widget, times, interval) { let w = (widget.visible !== undefined ? widget : $scope.view.wdg[widget]);
if (!w || w.visible === undefined) { throw "Cannot blink this widget"; }
$interval(() => w.visible = !w.visible, interval, times);
Invoke the function like this:
blink(widget, times, delay);where widget is either the id of the widget (e.g. modelItem-1) or the widget itself (e.g. $scope.view.wdg['modelItem-1']).
The other two numbers are the number of times that you want visibility to change, and the amount of milliseconds between each visibility change.
Here follow some examples.
You want to blink the widget 4 times with a 300 ms interval (and leave the widget visible at the end):
blink('modelItem-1', 2*4, 300);
You want to blink the widget 4 times with a 300 ms interval (and leave the widget not visible at the end):
blink('modelItem-1', 2*4+1, 300);
You can comment and suggest additional quarks if you want.
Alessio
