What's New in Vuforia Studio 9.25.0
  • March 27, 2025
  • 0 replies
  • 453 views
Vuforia Studio
  • New Contour Shader
    • A new contour shader is available for outlining objects. For more information, see Shaders.
  • New virtualMode Parameter for Highlight Shader
    • A new virtualMode parameter is available for the highlight shader that renders highlighted parts as opaque. For more information, see Shaders.
  • New Opacity Parameter for Flow Shader
    • A new opacity parameter is available for the flow shader. For more information, see Shaders.
  • State-based Model Target Updates
  • Specify New Source Directory for Projects and Assets
  • Support for macOS Sequoia
    • macOS Sequoia is now supported.
  • Support for ThingWorx 9.7
    • ThingWorx 9.7 is now supported.
  • ThingWorx 9.3 No Longer Supported
    • ThingWorx 9.3 is no longer supported.
  • Upcoming AngularJS Update for Vuforia Studio
    • In the upcoming 10.0 release (targeted for May 2025), Vuforia Studio will transition from AngularJS 1.5 and Ionic 1.3.3 to AngularJS 1.8.3 to modernize the platform and maintain high security standards. These future changes may affect custom JavaScript code in Home.js of your experiences and may require updates to ensure your existing experiences function correctly after republishing with the new version. For more information, see Upcoming AngularJS Update for Vuforia Studio.
Vuforia View
  • Vuforia View for 32–bit Android No Longer Available in Google Play Store
    • Vuforia View for 32-bit Android devices will be removed from the Google Play Store. If you already have Vuforia View installed on 32-bit Android devices, you can continue to use the app, but no updates will be available. Vuforia View for 64-bit Android devices will remain available.
Experience Service
  • Support for PostgreSQL 16.8
    • PostgreSQL 16.8 is now supported
  • RHEL 8.10 Support Ending in Experience Service 10.0
    • Beginning with the next release of the Experience Service (10.0), Red Hat Enterprise Linux 8.10 will no longer be supported.
  • Ubuntu 20 Support Ending in Experience Service 10.0
    • Beginning with the next release of the Experience Service (10.0), Ubuntu 20 will no longer be supported.
Bug Fixes
  • See Bug Fixes for additional information on bugs resolved in this release
