Feb 19, 2016 8:02 PM UTC
Access is not permitted to advanced query capabilities
Hello ,
I'm writing advanced API Query to fetch the all parts latest version and iteration but I'm unable to execute the query. Here my code:
import wt.fc.QueryResult;
import wt.inf.library.WTLibrary;
import wt.part.WTPart;
import wt.part.WTPartMaster;
import wt.query.ClassAttribute;
import wt.query.OrderBy;
import wt.query.QueryException;
import wt.query.QuerySpec;
import wt.query.SQLFunction;
import wt.query.SearchCondition;
import wt.query.SubSelectExpression;
* @author mgangappa
public class Extractor {
    public static void main(String[] args) {
        Extractor ex = new Extractor();
        ex.getAllPartsLatestVersionAndIteration();
    public void getAllPartsLatestVersionAndIteration() {
        try {
            final QuerySpec qs = new QuerySpec();
            qs.setAdvancedQueryEnabled(true);
            final int lib = qs.addClassList(WTLibrary.class, false);
            final int masterIndex = qs.addClassList(WTPartMaster.class, false);
            final int partIndex = qs.addClassList(WTPart.class, true);
            final QuerySpec subSelect = new QuerySpec();
            final int partSubInt = subSelect.appendClassList(WTPart.class, false);
            final SQLFunction max = SQLFunction.newSQLFunction(SQLFunction.MAXIMUM, new ClassAttribute(WTPart.class, "iterationInfo.branchId"));
            subSelect.appendSelect(new ClassAttribute(WTPart.class, "masterReference.key.id"), new int[]{partSubInt}, true);
            subSelect.appendSelect(max, new int[]{partSubInt}, true);
            subSelect.setAdvancedQueryEnabled(true);
            subSelect.appendGroupBy(new ClassAttribute(WTPart.class, "masterReference.key.id"), new int[]{partSubInt}, true);
            qs.appendWhere(new SearchCondition(WTLibrary.class, WTLibrary.NAME, SearchCondition.NOT_LIKE, "%test%"), new int[]{lib});
            qs.appendAnd();
            qs.appendWhere(new SearchCondition(WTPartMaster.class, "containerReference.key.id", WTLibrary.class, "thePersistInfo.theObjectIdentifier.id"), new int[]{masterIndex, lib});
            qs.appendAnd();
            qs.appendWhere(new SearchCondition(WTPart.class, "masterReference.key.id", WTPartMaster.class, "thePersistInfo.theObjectIdentifier.id"), new int[]{partIndex, masterIndex});
            qs.appendAnd();
            qs.appendWhere(new SearchCondition(WTPart.class, WTPart.LATEST_ITERATION, SearchCondition.EQUAL, true), new int[]{partIndex});
            qs.appendAnd();
            final SubSelectExpression inList = new SubSelectExpression(subSelect);
            inList.setAccessControlRequired(false);
            qs.appendWhere(new SearchCondition(new ClassAttribute(WTPart.class, "iterationInfo.branchId"), SearchCondition.IN, inList), new int[]{partIndex});
            qs.appendOrderBy(new OrderBy(new ClassAttribute(WTPartMaster.class, WTPartMaster.NUMBER), true), new int[] {masterIndex});
            QueryResult qr = ExecuteQueryInServerContext.executeAdvanceQueryInServer(qs, "executeQuery");
        } catch (QueryException ex) {
            ex.printStackTrace();
I'm executing it in the RemoteMethodServer.invoke (see below code):
import java.lang.reflect.InvocationTargetException;
import java.rmi.RemoteException;
import wt.fc.PersistenceHelper;
import wt.fc.PersistenceServerHelper;
import wt.method.RemoteAccess;
import wt.method.RemoteMethodServer;
import wt.pds.StatementSpec;
import wt.util.WTException;
* @author mgangappa
public class ExecuteQueryInServerContext implements RemoteAccess {
    public static QueryResult executeAdvanceQueryInServer(QuerySpec query, String method) {
        Class[] pClasses = new Class[1];
        pClasses[0] = QuerySpec.class;
        Object[] pObjects = new Object[1];
        if (query == null) {
            return null;
        } else {
            pObjects[0] = query;
        try {
            return (QueryResult) RemoteMethodServer.getDefault().invoke(method, ExecuteQueryInServerContext.class.getName(), null, pClasses, pObjects);
        } catch (RemoteException ex) {
        } catch (InvocationTargetException ex) {
        return null;
    public static QueryResult executeQuery(QuerySpec qs) throws WTException {
        System.out.println("executeQuery => PersistenceServerHelper ");
        QueryResult result = PersistenceServerHelper.manager.query(qs);
        return result;
    public static QueryResult executeQueryManager(QuerySpec qs) throws WTException {
        QueryResult result = PersistenceHelper.manager.find((StatementSpec) qs);
        return result;
But I'm keep getting the below error:
nServerContext, executeQuery, , 0, 0, 0.0, 0, 0.0, 0.01, 0.007444714
(wt.pds.pdsResource/23) wt.pds.AdvancedQueryAccessException:
Access is not permitted to advanced query capabilities.
  at wt.pds.SQLDatabasePds.query(SQLDatabasePds.java:616)
  at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1108)
  at wt.pom.PersistentObjectManager.query(PersistentObjectManager.java:1017)
  at wt.fc.StandardPersistenceManager._query(StandardPersistenceManager.java:1878)
  at wt.fc.StandardPersistenceManager.query(StandardPersistenceManager.java:1417)
  at wt.fc.StandardPersistenceManager.query(StandardPersistenceManager.java:1301)
  at com.google.extractor.ExecuteQueryInServerContext.executeQuery(ExecuteQueryInServerContext.java:50)
What I'm doing wrong? Do I need to set or change config?
Manjunath Reddy
ShirishMorkhade
Mar 2, 2016 12:19 PM UTC
Hi Lori,
    Yes, this is resolved with the attached modified Java files. Manjunath Reddy confirms as this is resolved.
Shirish
23-Emerald II
Feb 27, 2016 12:32 AM UTC
Hi Manjunath,
I noticed that you opened a case with Tech Support to investigate this issue (C12944368). Did using the QuerySpec.setAdvancedQueryEnabled(true) method in your code resolve this issue?
ShirishMorkhade
Hi Lori,
Shirish
Mar 2, 2016 4:27 PM UTC
You should mark this post as answered.
