code to check Revision of Promoted object
  • February 20, 2014
  • 652 views
Hi All,
Can anyone share the java logic for capturing the revision of the promotable? (part/epm/doc)
I want to check they are Revision 'A' in an initial condition in the workflow.
Thanks!
Vaughn
Vaughn,
Below is the sample code. Check if work for you
private static void revise(PromotionNotice pn) {
//wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
try {
wt.fc.QueryResult qr = wt.maturity.MaturityHelper.service.getPromotionTargets(pn);
while(qr.hasMoreElements()) {
// For all promotables
Object obj = qr.nextElement();
if (obj instanceof wt.lifecycle.LifeCycleManaged) {
// Get revision, and check if revision is not numeric
wt.enterprise.RevisionControlled rc = (wt.enterprise.RevisionControlled)obj;
String version = rc.getIterationDisplayIdentifier().toString();
System.out.println("+version);
//if (version equal to A)
//Do Something like
// else
// do Something
else {
System.out.println("No Lifecycle Managed object found!");
} catch (wt.maturity.MaturityException me) {
me.printStackTrace();
} catch (wt.util.WTException wte) {
wte.printStackTrace();
// END
Hope this helps !!!
Shreyas
