Default Units
  • April 14, 2011
  • 0 replies
  • 386 views
I would like to change the values in the default units pull down that show in then new Part dialog and in the Product Structure Explorer from SI to USCS. I assume from previous threads that I do this by changing the codebase/wt/part/wt.part.QuantityUnitRB.ser file values through enumCustomize. If that is correct, where do I find the correct keys for USCS units. I assume the key for inches is in and in^2 is sq_in, but I am not sure.
Jon
