How to update parameters in windchill after part checkout & did modification in paramter level inside creo?
Hi
Ex:
I uploaded part inside windchill with paramter (part _name & part_number) which derive from creo.
Then later I am in need to change the part_number & part name for the same part which uploaded previously.
I checkout to creo & did the parameter change and checkin again .I understood that the changed parameter is not updated inside windchill ?
Is there any solution to sort out this issue ???
