Launching Pro/E file through IE
  • November 8, 2012
  • 3 replies
  • 765 views
SometimesI have folks using IE for PDMLink and they willtry to open Pro/E thefiles from there(Not using ProductView. Thisdoes not work. My question is: should it work or is it not intended to launch Pro/E from the IE browser. If it is then I have something wrong with my setup.
Sorry if the Subjectwas not too clear, it's late
TIA
Bob Lohbauer
It will work BUT only if you have session of Pro/E already running.
The .pha file that it tries to open cannot launch Pro/E.
Thank you,
Ben H. Loosli
USEC, INC.
Actually, if your file associations are set up correctly, opening the .pha file will launch a session of ProE.
ASSOC .pha=phaFile
FTYPE phaFile=c:\Ptc\proeWF4\bin\proe.exe "%%1"
You just have to watch out for the behavior in different use cases, particularly if you have Windchill. (In that case you can only really open files in IE from the commonspace, not from the workspace, since the pha file is interpreted as a request to add the file to a workspace and open.)
John Frankovich
Lohbauer1-VisitorAuthor
Thanks to Ben Loosli and John Frankovich for responding.
With Pro/E concurrently running you can open a Pro file from the WC Internet Browser. And thanks to John for adding the .pha associations Command line input.
Bob
ASSOC .pha=phaFile
John Frankovich
