PartsLink failing reload and update
I'm attempting to check-in a classification from Counterpart into PartsLink. It uploads to PDMLink/PartsLink just fine (I can see it in the Classification Administrator and the PSE) but it's the second part of the check-in, when it tries to Update the Classification, that it can't get past. If I let it go, the loading bar runs for 30 minutes then throws an error saying it can't connect to PartsLink. If I end it prematurely and attempt to reloadthe classificationfrom the Windcill Shell, PartsLink throws a "Replica 1 failed" error which implies that the tables are corrupted and need to be dropped then remade.
The file I'm attempting to check-in is simply the Demo class with most of the sub-classes deleted.
If I can't even check it in, I'm not sure where else to start.
