20-Turquoise
November 26, 2012
Serious Wildfire 5 M160 family table and workspace synchronization issues
  • November 26, 2012
  • 11 replies
  • 1591 views
PDMLink 9.1 M070
Wildfire 5.0 M160
We have discovered the following 2 issues with Wildfire 5 M160 and PDMLink 9.1 M070.
Issue 1:
After modification by Pro/Engineer Wildfire 5.0 M160 and checkin to PDMLink 9.1 M070 family table
controlled angle dimensions are incorrect when opened in previous builds of WF5 and Creo 2.0 M020.
This is reproducible as follows:
1. using Wildfire 5 M150 (or earlier build) checkin family table that includes angle dimensions
2. using Wildfire 5 M160 modify and checkin this family table
3. using Wildfire 5 M150 (or earlier build or Creo2.0 M020) open the family table version created
    by WF5 M160
4. note the family table controlled angle dimensions are now incorrect (ie what should be 30 is 0.78)
Issue 2:
Under certain circumstances Pro/Engineer Wildfire 5.0 M160 exits attempting to Synchronize the
workspace. This happens after renaming components in Windchill and then attempting the Synchronize
the workspace. It doesn't crash with every rename/synchronization but when it does happen there are
only 2 ways to synchronize the workspace. You can fire up Pro/Engineer M150 (or earlier) to
synchronize or delete/rename the local workspace cache and register the Windchill server.
I have calls open to PTC on both of these issues with spr 2157859 for issue 1 and spr 2157091 for
issue 2.
In my opinion issue 1 is a very serious issue because users on earlier builds of WF5 or Creo 2.0
have incorrect geometry when opening these WF5 M160 modified family tables. The combination of the 2
issue is very bad because you have this:
1. WF5 M160 crashing when synchronizing workspaces
or
2. going back to WF5 M150 and getting incorrect family tabled parts
Has anybody else experienced these 2 issues with WF5 M160?
20-Turquoise
December 28, 2012
