18-Opal
July 27, 2011
Single user Performance Test
  • July 27, 2011
  • 2 replies
  • 921 views
Hey there,
Anyone successfully use the Single user Performance Test from PTC?
------ PRO_MACHINE_TYPE ----------
x86e_win64
------ JLINKCLASSPATH ----------
C:\Users\mmd01\Documents\SPT\lib\jlinktests.jar;"C:\ptc\proeWildfire 4.0"\text\java\pfcasync.jar
------ JLINKASYNCFLAGS ----------
ECHO is off.
------ JLINKASYNCFLAGS4 ----------
ECHO is off.
------ JAVA_ASYNC_JL_START ----------
"C:\ptc\proeWildfire 4.0"\x86e_win64\obj\JRE\bin\java.exe
------ CLASSPATH ----------
------ PATH ----------
C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Common Files\Roxio Shared\DLLShared\;
C:\Program Files (x86)\Common Files\Roxio Shared\10.0\DLLShared\;C:\PROGRA~2\IBM\CLIENT~1;C:\PROGRA~2\IBM\CLIENT~1\Shared;C:\PROGRA~2\IBM\CLIENT~1\Emulator;C:\p
tc\proengineer\bin;C:\ptc\proeWildfire 5.0\bin;C:\ptc\proeWildfire 4.0\bin;"C:\ptc\proeWildfire 4.0"\x86e_win64\lib
----- Input File Name -----
ECHO is off.
Starting the test...
Exception in thread "main" java.lang.NoClassDefFoundError: com/ptc/cipjava/jxthrowable
Caused by: java.lang.ClassNotFoundException: com.ptc.cipjava.jxthrowable
at java.net.URLClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
Could not find the main class: com.ptc.jlinkwindchilltool.pfcWindchillJlink. Program will exit.
-marc
There was a talk on this in Vegas. Attached.
David Haigh
mdebower18-OpalAuthor
18-Opal
July 27, 2011
Cool, thanks for the file. Too much to see at Vegas, and I missed this one. dangnabit
