Soft type versus Hard type performance test?
  • October 3, 2014
  • 2 replies
  • 1376 views
Is there any PTC documentation related to Performance Benchmark test - Soft Typing versus Hard Typing ?
I guess that performances between soft typing and hard typing are the same and depend only from amount of the attributes and attributes sizes. If type A has more attributes then type B, so A will stored slowly then B.
There are not many documents that mark the performance differences between modeled and soft types.
I was able to find some testing that was done on attributes. (see below) (blank shows normal response times)
Modeled Attribute
Standard Attributes
Global Attributes
Structure Navigation & Where UsedHigher
Folder Listing
HigherHigher
Create
Higher
Retrieve
Higher
Checkout
Higher
Update
Higher
CheckinHigher
DeleteHigher
In the Database Modeled Types have their own table as opposed to Soft Types.
The concern being that if you have a lot of Soft Types you may need to check the indexing to ensure the same performance.
Here is an article that I found that mentions using caching to prevent some small performance issue when using many soft type and attributes.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS28189&source=tssearch
  • xconfmanager -p -t codebase/wt.properties -s com.ptc.core.lwc.PrimeTypeCache=true
You can also find the instructions for the Modeled to Soft Type utility in the Customizers guide here:
http://support.ptc.com/WCMS/files/154113/en/10_1_M040_WindchillCustomizationGuide.pdf#150
Hope this helps, and good luck with your implementations!
Jarrett
hmikic1-VisitorAuthor
Thank you for your help. It helps.
Helena
