avillanueva
23-Emerald I
23-Emerald I
March 6, 2013
Syncing Find numbers and Line numbers
  • March 6, 2013
  • 0 replies
  • 397 views
I have no need for both but I would like to take advantage of BOM Notes which rely on Find numbers. Has anyone see a way to sync these? Is there anything in 10.1 that changes this if not now? I am leaning toward customization. I can handle the existing data with a SQL script easy enough.
Antonio Villanueva - Sr. Software Engineer - ISR Systems
UTC AEROSPACE SYSTEMS
100 Wooster Heights Road, Danbury, CT 06804
Tel: +1 203 797 5682
antonio.villanueva@utas.utc.com<">mailto:antonio.villanueva@utas.utc.com> www.utcaerospacesystems.com
CONFIDENTIALITY WARNING: This message may contain proprietary and/or privileged information of UTC Aerospace Systems and its affiliated companies. If you are not the intended recipient please 1) do not disclose, copy, distribute or use this message or its contents, 2) advise the sender by return e-mail, and 3) delete all copies (including all attachments) from your computer. Your cooperation is greatly appreciated.
