UICopmonentValidators for Soft Types
  • November 15, 2013
  • 3 replies
  • 888 views
10.1 M040
Does anyone know how to register a UIComponentValidator for a soft type? For example I have soft typed the Change Task to an Engineering Change Task. I want to register a validator but I only want it to be called when an Engineering Change Task is being created and NOT when a Change Task is being created. I found in the Customization Guide on page 803 that this can be done but I haven't seen an example with a soft type.
<service context="default" name="com.ptc.core.ui.validation.UIComponentValidator">
<option serviceclass="com.steelcase.enterprise.change2.validators.ECACreateWizardValidator"&lt;br"/> selector="ECACreateWizardValidatorVK"
requestor="wt.change2.WTChangeActivity2"
targetFile="codebase/service.properties"/>
</service>
The requestor attribute is supposed to be able to do this but I'm wondering if it's not working because my soft type class is not defined in actions.xml. Do I have to "duplicate" the blocks for the changeTask for my EngineeringChangeTask in actions.xml? Any thoughts?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image003.jpg@01CEE209.8D6FA3D0]
Same syntax as OIR, like with "WCTYPE|" leading, but it's been awhile.
Suggest trying both ways.
I personally find it easier to against WTObject one of these, then setup a
properties file to eval type and then load another class for biz logic
execution.
Yes David I tried that syntax. The reason I can't put my soft type in as the requestor is because my soft type doesn't have a definition block in the actions.xml file...and it shouldn't.
[cid:image002.jpg@01CEE431.F12DBCC0]
Put the validator on the modeled class associated actions.xml have it run always, but react only if soft type is correct.
Sent from my Verizon Wireless 4G LTE Smartphone
