Unix/Linux startup scripts
  • November 23, 2010
  • 2 replies
  • 2877 views
Gurus,
Can someone provide a sample *NIX start script for Tomcat and/or Windchill? We followed a Suggested Technique or something I found (sorry, lost the reference) for scripts to put in the init.d folder, using the 'nohup' prefix to launch. If we run the scripts, we get terminal windows opening up for Tomcat, ServerManager and the MethodServer. Then when we log out, the windows close and these services die.
Here is a code snippet:
cmdtext="starting"
echo "tomcat $cmdtext."
status=`nohup $CATALINA_HOME/bin/wttomcat_start $2>&1`
Do we need to set the DISPLAY variable to null to force output from these scripts to go to the log files? Should we be running the actual start command as a background job?
Appreciate any and all suggestions to resolve this.
Mark Plimley NxRev, Inc.
PLM Implementer/Trainer
20-Turquoise
November 24, 2010
On 11/23/10 12:02, Mark Plimley wrote:
> Gurus,
See attached for what I use here on Solaris. This script lives at:
/etc/rc3.d/S92windchill
> die.
> cmdtext="starting"
> a background job?
The ootb xterms are nice for the install because you have the xterm windows
opening after installation for that "warm fuzzy feeling". In production use
however the xterms are worse than useless. You can get rid of them by following
the instructions here:
Attached is what I usually do:
Note: If you have partslink, you have to change the actual PL_start.sh to incorporate set_env.sh:
PL_start.sh
#!/bin/sh
JAVA_HOME=/usr/java/latest
WORK_DIR=/ptc/Windchill/partslink
TOMCAT_HOME=/ptc/Tomcat
CATALINA_HOME=$TOMCAT_HOME
PL_CONFIGFILE=$WORK_DIR/conf/main.properties
PL_CLASSPATH=$WORK_DIR/codebase/WEB-INF/classes:codebase/WEB-INF/lib/CounterPartWeb.jar:codebase/WEB-INF/lib/ptlWeb.jar:lib/OracleThinDrivers.jar:lib/PartsLinkService.jar:lib/SDbase.jar:lib/SDsqlserver.jar:lib/SDutil.jar:lib/commons-lang.jar
export JDK_PATH WORK_DIR TOMCAT_HOME CATALINA_HOME PL_CONFIGFILE PL_CLASSPATH
cd $WORK_DIR
MAX_MEMORY=128
$JAVA_HOME/bin/java -Xmx${MAX_MEMORY}m -cp $PL_CLASSPATH nitidus.util.rmi.cServerManager $PL_CONFIGFILE
I created a wcappctl file in /ptc/Shortcuts, /ptc/links/, or $WT_HOME/bin. I can improve it to check on processes prior to starting other dependant apps. But, here is what I have:
#!/bin/sh
# chkconfig: 345 99 10
# description: Windchill Applicaitons auto start-stop script.
LOGMSG="logger -puser.alert -s "
# Setting the environments paths
export ORACLE_HOME=/ptc/oracle/products/client/11G
export WT_HOME=/ptc/Windchill
export PARTSLINK_HOME=$WT_HOME/partslink
export JAVA_HOME=/usr/java/latest
export TOMCAT_HOME=/ptc/Tomcat
export CATALINA_HOME=$TOMCAT_HOME
export COGNOS_HOME=/ptc/Reporting
export DIRECTORY_SERVER_HOME=/ptc/DirectoryServer/server
export APACHE_HOME=/ptc/Apache
export LOGS_HOME=/ptc/ArchiveLogs
export FASTSEARCH=/ptc/IndexSearch/InStream_5.1/instream
export SHLIB_PATH=$ORACLE_HOME/lib:/usr/lib
export SQLPATH=$WT_HOME/db/sql3:$ORACLE_HOME/sqlplus/admin
export TNS_ADMIN=$ORACLE_HOME/network/admin
export ORACLE_SID=plmora
export ORAENV_ASK=NO
export NLS_LANG=American_America.utf8
# Set environment paths
export PATH=$JAVA_HOME/bin:$JAVA_HOME/jre/bin:$APACHE_HOME/bin:$TOMCAT_HOME/bin:$WT_HOME/bin:PARTSLINK_HOME/bin:$COGNOS_HOME/bin:$ANT_HOME/bin:$ORACLE_HOME/bin:$PATH:.
# Set WC_OWNER to the user id of the owner of the Windchill Applications
export WC_OWNER=wcadmin
# Set INDEX_OWNER to the user id of the owner of the Instream FastSearch Applicaitons
export INDEX_OWNER=instream
/bin/date >> $LOGS_HOME/wcstart.log 2>&1
/bin/date >> $LOGS_HOME/wcstop.log 2>&1
/bin/chmod -R 777 $LOGS_HOME
/ptc/links/wc_status.sh
case "$1" in
'start')
echo "Make sure there are no hanging or running java processes for a full start"
echo "Make sure there are no hanging or running java processes for a full start" >> $LOGS_HOME/wcstart.log 2>&1
$JAVA_HOME/bin/java -jar /ptc/links/JavaCleanup.jar -kill >> $LOGS_HOME/wcstart.log 2>&1
echo "Trimming All Windchill Application Logs"
/ptc/links/LogTrimming.sh
echo "Starting All Windchill Applications:"
echo "Starting Directory Server, Instream, Cognos, Windchill, Tomcat and Apache "
echo "Ensuring Aphelion is not running"
/ptc/Aphelion/instTemp/cdsDaemon stop >> $LOGS_HOME/wcstart.log 2>&1
echo "Starting Directory Server"
$DIRECTORY_SERVER_HOME/bin/start-ds >> $LOGS_HOME/wcstart.log 2>&1
echo "Starting Instream Index Search"
/bin/su - $INDEX_OWNER -c "$FASTSEARCH/bin/nctrl start" >> $LOGS_HOME/wcstart.log 2>&1
echo "Starting Cognos"
/bin/su - $WC_OWNER -c "/ptc/Reporting/bin/cogconfig.sh -s" >> $LOGS_HOME/wcstart.log 2>&1
echo "Starting Windchill PartsLink Method Server"
/bin/su - $WC_OWNER -c "/ptc/Windchill/partslink/bin/PL_start.sh &" >> $LOGS_HOME/wcstart.log 2>&1
echo "Starting Windchill Method Server"
/bin/su - $WC_OWNER -c "/ptc/Windchill/bin/windchill start" >> $LOGS_HOME/wcstart.log 2>&1
echo "Starting Tomcat(s)"
rm -rf $TOMCAT_HOME/work
/bin/su - $WC_OWNER -c "/ptc/links/tomcat_start" >> $LOGS_HOME/wcstart.log 2>&1
echo "Starting Apache"
$APACHE_HOME/bin/apachectl -k start -D SSL >> $LOGS_HOME/wcstart.log 2>&1
'stop')
echo "Stopping All Windchill Applications:"
echo "Stopping Directory Server, Instream, Cognos, Windchill, Tomcat and Apache "
echo "Stopping Apache"
$APACHE_HOME/bin/apachectl stop >> $LOGS_HOME/wcstop.log 2>&1
echo "Stopping Tomcat"
/bin/su - $WC_OWNER -c /ptc/links/tomcat_stop >> $LOGS_HOME/wcstop.log 2>&1
echo "Stopping Windchill Method Server"
/bin/su - $WC_OWNER -c "/ptc/Windchill/bin/windchill stop" >> $LOGS_HOME/wcstop.log 2>&1
echo "Stopping Windchill PartsLink Method Server"
/bin/su - $WC_OWNER -c "/ptc/Windchill/partslink/bin/PL_stop.sh" >> $LOGS_HOME/wcstop.log 2>&1
echo "Stopping Cognos"
/bin/su - $WC_OWNER -c "/ptc/Reporting/bin/cogconfig.sh -stop" >> $LOGS_HOME/wcstop.log 2>&1
echo "Stopping Instream Index Search"
/bin/su - $INDEX_OWNER -c "$FASTSEARCH/bin/nctrl stop" >> $LOGS_HOME/wcstop.log 2>&1
echo "Stopping Directory Server"
$DIRECTORY_SERVER_HOME/bin/stop-ds >> $LOGS_HOME/wcstop.log 2>&1
sleep 60
echo "Kill any hanging or running java processes for a full stop"
echo "Kill any hanging or running java processes for a full stop" >> $LOGS_HOME/wcstop.log 2>&1
$JAVA_HOME/bin/java -jar /ptc/links/JavaCleanup.jar -kill >> $LOGS_HOME/wcstop.log 2>&1
'restart')
echo "Pause for 5 minutes"
sleep 300
echo "Kill any hanging java processes"
echo "Kill any hanging java processes" >> $LOGS_HOME/wcstop.log 2>&1
'quickstart')
echo "Quick Start of Windchill Applications:"
echo "Starting Windchill, Partslink, Tomcat and Apache "
'quickstop')
echo "Stopping Only Windchill Applications:"
echo "Stopping Windchill, PartsLink, Tomcat and Apache "
'quickrestart')
echo "Stopping Windchill Applications:"
echo "Stopping only Windchill, PartsLink, Tomcat and Apache "
echo "Pause for 2 minutes"
sleep 120
echo "Starting only Windchill, Partslink, Tomcat and Apache"
/bin/su - $WC_OWNER -c "/ptc/Windchill/partslink/bin/PL_start.sh" >> $LOGS_HOME/wcstart.log 2>&1
'status')
echo $"Usage: $0 {start|stop|restart|quickstart|quickstop|quickrestart|status}"
exit 1
esac
I also created a LogTrimming.sh file to nightly compress and backup the logs and trim them incase they grow and cause performance issues:
#!/bin/ksh
export WT_LOGS=/ptc/ArchiveLogs
export DS_HOME=/ptc/DirectoryServer/server
export PATH=$JAVA_HOME/bin:$APACHE_HOME/bin:$TOMCAT_HOME/bin:$WT_HOME/bin:$JAVA_HOME/bin:$COGNOS_HOME/bin:/usr/bin:/sbin:$PATH
mkdir $WT_LOGS/$(date +%y%m%d)
## Nulling DirectoryServer Logs As Root
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/DirectoryServer.$(date +%y%m%d%H%M).jar $DS_HOME/logs/.
/bin/cat /dev/null > $DS_HOME/logs/access
/bin/cat /dev/null > $DS_HOME/logs/errors
/bin/cat /dev/null > $DS_HOME/logs/replication
/bin/cat /dev/null > $DS_HOME/logs/server.out
## Nulling Apache Logs
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/Apache.$(date +%y%m%d%H%M).jar $APACHE_HOME/logs/.
/bin/cat /dev/null > $APACHE_HOME/logs/error_log
/bin/cat /dev/null > $APACHE_HOME/logs/mod_jk.log
/bin/cat /dev/null > $APACHE_HOME/logs/access_log
/bin/cat /dev/null > $APACHE_HOME/logs/ssl_request_log
## Nulling Tomcat Logs
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/Tomcat.$(date +%y%m%d%H%M).jar $TOMCAT_HOME/logs/.
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $TOMCAT_HOME/logs/catalina.out"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $TOMCAT_HOME/logs/windchill.log"
## Nulling Windchill Logs
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/Windchill.$(date +%y%m%d%H%M).jar $WT_HOME/logs/.
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $WT_HOME/logs/DCA.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $WT_HOME/logs/HTTPGateway.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $WT_HOME/logs/BackgroundMethodServer.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $WT_HOME/logs/BackgroundMethodServerWVS1.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $WT_HOME/logs/BackgroundMethodServerWVS2.log"
## Nulling Cognos Logs
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/Cognos.$(date +%y%m%d%H%M).jar $COGNOS_HOME/logs/.
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/tomcat.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cbs_cnfgtest_run.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cbs_isrunning.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cbs_run.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cbs_start.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cbs_stop.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cbsdefault.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/ccl.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cogconfigipf.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > $COGNOS_HOME/logs/cogserver.log"
## Nulling Instream Logs
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/Instream.$(date +%y%m%d%H%M).jar $FASTSEARCH/var/log/.
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/httpd.access_log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/httpd.error_log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/adminserver/sbc.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/adminserver/sfe.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/adminserver/silo-index-admin.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/adminserver/adminserver.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/anchorserver/anchorserver-storage.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/cachemanager/cachemanager.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/clarity/clarity.log/clarity_webcluster.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/configserver/configserver.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/contentdistributor/contentdistributor.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/crawler/crawler.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/esp4j-apps/logtransformer.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/esp4j-apps/resourceservice-stop.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/esp4j-apps/resourceservice.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/indexer/indexer.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/indexingdispatcher/indexingdispatcher.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/matcherserver/completionserver.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/nameservice/nameservice.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/nodecontroller/nctrl.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/procserver/procserver_1.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/qrserver/qrserver.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/rtsearch/dictionary_producer.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/fdispatch-15700.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/fdispatch-tld.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/fsearch-0.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/fsearch-1.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/fdispatch-2.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/fdispatch-2_1.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/search-1.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/searchctrl/topfdispatch.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/syslog/all.log"
/bin/su - $INDEX_OWNER -c "/bin/cat /dev/null > $FASTSEARCH/var/log/syslog/lasterror.log"
## Nulling /var/logs
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/var.$(date +%y%m%d%H%M).jar /var/log/.
/bin/cat /dev/null > /var/log/anaconda.log
/bin/cat /dev/null > /var/log/boot.log
/bin/cat /dev/null > /var/log/hp-fc-enablement.log
/bin/cat /dev/null > /var/log/hpUtil.log
/bin/cat /dev/null > /var/log/mysqld.log
/bin/cat /dev/null > /var/log/scrollkeeper.log
/bin/cat /dev/null > /var/log/Xorg.0.log
/bin/cat /dev/null > /var/log/yum.log
/bin/cat /dev/null > /var/log/tomcat5/catalina.out
/bin/cat /dev/null > /var/log/audit/audit.log
/bin/cat /dev/null > /var/log/cups/access_log
/bin/cat /dev/null > /var/log/cups/error_log
/bin/cat /dev/null > /var/log/gdm/0.log
/bin/cat /dev/null > /var/log/httpd/access_log
/bin/cat /dev/null > /var/log/httpd/error_log
/bin/cat /dev/null > /var/log/pm/suspend.log
/bin/cat /dev/null > /var/log/prelink/prelink.log
## Nulling /ptc/ArchiveLogs
$JAVA_HOME/bin/jar -cvf $WT_LOGS/$(date +%y%m%d)/ArchiveLogs.$(date +%y%m%d%H%M).jar /ptc/Archivelogs/.
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > /ptc/ArchiveLogs/wcstart.log"
/bin/su - $WC_OWNER -c "/bin/cat /dev/null > /ptc/ArchiveLogs/wcstop.log"
## This Script deletes all files under $WT_LOGS/$(date +%y%m%d) and $WT_HOME/logs that are
## have not been accessed within 7, 15 and 28 days respectfully
date
find $WT_HOME/logs $TOMCAT_HOME/logs $COGNOS_HOME/logs $DS_HOME/logs -mtime +7 -exec rm -f {} \;
find $WT_LOGS -mtime +28 -exec rm -f {} \;
