Windchill r10 Oracle Install
  • March 18, 2011
  • 2 replies
  • 3263 views
Hi All,
I'm just about to install Windchill R10 for testing and see that it requires Oracle 11g, is there a guide that shows the install for this as the one with PSI is for oracle 10 and 11 installs differently (basically will install everything)
Chris,
I have you tried using the Standalone component option. You can use the bundled Pro- Intralink oracle and go ahead with the install.
Regards
~Syed
Thanks for the response, I dont have the disks for that as we are PDMLink
Chris,
Just to clarify, are you asking for guidance installing Oracle 11g?
It sounds like you are sayng the default Oracll 11g instalation installs everything, so you are looking for guidance on what is not necessary to install for use with PDMLink. Is that right?
