How to run background task periodically
Hi.
I need run some code in Windchill to update objects. I need start this task at specified time and rerun it in some period.
So i tried to use java.util.TimerTask implementation.
Some code example i used:
public class MyServiceManager extends wt.services.StandardManager {
    private static Logger LOGGER = LogR.getLogger(MyServiceManager .class.getName());
    public static MyServiceManager newMyServiceManager () throws WTException {
        MyServiceManager instance = new MyServiceManager ();
        instance.initialize();
        return instance;
    @Override
    protected synchronized void performStartupProcess() throws ManagerException {
        try {
            /*some code to init firstTime and period*/
            Timer timer = new Timer();
            timer.scheduleAtFixedRate(new MyTimerTask(), firstTime, period);
        } catch (Exception e) {
            LOGGER.error(e.getMessage(), e);
public class MyTimerTask extends java.util.TimerTask {
    private static Logger LOGGER = LogR.getLogger(MyTimerTask.class.getName());
    public MyTimerTask() {
    @Override
    public void run() {
        try {
            QuerySpec querySpec = new QuerySpec();
            //fill query spec with conditions
            QueryResult qr = PersistenceHelper.manager.find((StatementSpec) querySpec); // and i get exception here
In PersistenceHelper.manager.find i get exception:
Message:  Resource bundle/Message key = wt.pom.pomResource/0
(wt.pom.pomResource/0) wt.pom.POMInitException: A persistence error occurred. System message follows:
Nested exception is: wt.method.MethodServerException: No active method context
    at wt.method.MethodContext.getContext(MethodContext.java:1725)
    at wt.pom.PersistentObjectManager.getPom(PersistentObjectManager.java:289)
    at wt.fc.StandardPersistenceManager._query(StandardPersistenceManager.java:1993)
    at wt.fc.StandardPersistenceManager._find(StandardPersistenceManager.java:2022)
    at wt.fc.StandardPersistenceManager.find(StandardPersistenceManager.java:681)
    at sun.reflect.GeneratedMethodAccessor22.invoke(Unknown Source)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.lang.reflect.Method.invoke(Method.java:606)
    at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
    at com.sun.proxy.$Proxy9.find(Unknown Source)
What shouild i do to fix this? Or is there more appropriate way to run same task in Windchill?
I expect get java code example.
Thanks.
I wouldn't do it manually with a timer. Windchill has the ability to schedule jobs.
Have a look at the customization guide and search for the chapter: Procedure – Creating Custom Schedule Jobs
It works.
But is there a way to solve by background queue?
Yes, the task will probably running in the Methodserver. I don't have any solution to run it in the BMS. Perhaps somebody else can help...?
