POST request_OData REST API
Hello everyone!
I try to execute a post request, but get this error:
{"error":
 {"code":
 "INVALID_NONCE","message":"A potential security problem was detected. Refresh the
 page and try again. If the problem persists, contact your administrator."
I found this article:
https://www.ptc.com/en/support/article/CS312447
It says that a token is needed, but I already added it and still does not work.
Here is the request that I execute to get the token:
http://server/Windchill/servlet/odata/PTC/GetCSRFToken()
Here is my code for the post request:
import java.io.BufferedReader;
import java.io.IOException;
import java.io.InputStream;
import java.io.InputStreamReader;
import java.io.Reader;
import java.io.UnsupportedEncodingException;
import java.nio.charset.Charset;
import java.nio.charset.StandardCharsets;
import org.apache.http.HttpEntity;
import org.apache.http.auth.AuthenticationException;
import org.apache.http.auth.UsernamePasswordCredentials;
import org.apache.http.client.ClientProtocolException;
import org.apache.http.client.methods.CloseableHttpResponse;
import org.apache.http.client.methods.HttpPost;
import org.apache.http.entity.StringEntity;
import org.apache.http.impl.auth.BasicScheme;
import org.apache.http.impl.client.CloseableHttpClient;
import org.apache.http.impl.client.HttpClients;
public class Post {
	public static void main(String[] args) {
		try (CloseableHttpClient httpClient = HttpClients.createDefault()) {
			HttpPost httpPost = new HttpPost("http://server/Windchill/servlet/odata/ProdMgmt/Parts");
			String json = "{\r\n" +
					"\"Name\":\"TestWTPart_001\",\r\n" +
					"\"AssemblyMode\": {\r\n" +
					"\"Value\": \"separable\",\r\n" +
					"\"Display\": \"Separable\"\r\n" +
					"},\r\n" +
					"\"GatheringPart\" : false,\r\n" +
					"\"PhantomManufacturingPart\" : false,\r\n" +
					"\"Context@odata.bind\": \"Containers('OR:wt.pdmlink.PDMLinkProduct:48507000')\",\r\n" +
					"\"DefaultUnit\":\"kg\",\r\n" +
					"\"DefaultTraceCode\":\"X\",\r\n" +
					"\"Source\":\"buy\"\r\n" +
			StringEntity jsonEntity = new StringEntity(json);
			httpPost.setEntity(jsonEntity);
			UsernamePasswordCredentials credentials = new UsernamePasswordCredentials("wcadmin", "123");
			httpPost.setHeader(new BasicScheme().authenticate(credentials, httpPost, null));
			httpPost.setHeader("Content-Type", "application/json");
			httpPost.setHeader("CSRF_NONCE",
					"MY-TOKEN");
			CloseableHttpResponse response = httpClient.execute(httpPost);
			HttpEntity entity = response.getEntity();
			if (entity != null) {
				try (InputStream stream = entity.getContent()) {
					StringBuilder textBuilder = new StringBuilder();
				 try (Reader reader = new BufferedReader(new InputStreamReader
				 (stream, Charset.forName(StandardCharsets.UTF_8.name())))) {
				 int c = 0;
				 while ((c = reader.read()) != -1) {
				 textBuilder.append((char) c);
					System.out.println(textBuilder);
			System.out.println("\n" + response.getStatusLine().getStatusCode());
			response.close();
		} catch (UnsupportedEncodingException e) {
			e.printStackTrace();
		} catch (ClientProtocolException e) {
		} catch (IOException e) {
		} catch (AuthenticationException e) {
			// TODO Auto-generated catch block
Tell me, please, what am I doing wrong?
Thank you in advance!
Best Regards!
hlafkirAnswer
ok thank you for this light.
Can you try that please (working fine for me). Just replace the user-agent and the PDMLinkProduct oid with your one. You will then see what is going wrong with your code :
private void sendPost() throws Exception {
 String url = "http://pdm10.de/Windchill/servlet/odata/ProdMgmt/Parts";
 HttpClient client = HttpClientBuilder.create().build();
 HttpPost post = new HttpPost(url);
 // add header
 post.setHeader("User-Agent", USER_AGENT);
 BASE64Encoder enc = new sun.misc.BASE64Encoder();
 String username="wcadmin";
 String password="ts";
 String userpassword = username + ":" + password;
 String encodedAuthorization = enc.encode( userpassword.getBytes() );
 JSONObject json = new JSONObject();
 json.put("Name", "TestWTPartFromOdata");
 json.put("PhantomManufacturingPart" , false);
 //"GatheringPart": false,
 json.put("GatheringPart", false);
 HashMap<String, String> am_map = new HashMap<String, String>();
 am_map.put("Value", "separable");
 am_map.put("Display", "Separable" );
 json.put("AssemblyMode", am_map);
 HashMap<String, String> df_map = new HashMap<String, String>();
 df_map.put("Value", "ea");
 df_map.put("Display", "Each" );
 json.put("DefaultUnit", df_map);
 HashMap<String, String> dtc_map = new HashMap<String, String>();
 dtc_map.put("Value", "0");
 dtc_map.put("Display", "Untraced" );
 json.put("DefaultTraceCode", dtc_map);
 HashMap<String, String> src_map = new HashMap<String, String>();
 src_map.put("Value", "make");
 src_map.put("Display", "Make" );
 json.put("Source", src_map);
 HashMap<String, String> cfm_map = new HashMap<String, String>();
 cfm_map.put("Value", "standard");
 cfm_map.put("Display", "Standard" );
 json.put("ConfigurableModule", cfm_map);
 json.put("EndItem" , false);
 json.put("Context@odata.bind", "Containers('OR:wt.pdmlink.PDMLinkProduct:64091')");
 StringEntity params = new StringEntity(json.toString());
 "Name": "Part_P036",
 "AssemblyMode": {
 "Value": "separable",
 "Display": "Separable"
 "EndItem" : false,
 "DefaultUnit": {
 "Value": "ea",
 "Display": "Each"
 "DefaultTraceCode": {
 "Value": "0",
 "Display": "Untraced"
 "Source": {
 "Value": "make",
 "Display": "Make"
 "ConfigurableModule": {
 "Value" : "standard",
 "Display" : "Standard"
 "PhantomManufacturingPart": false,
 "Context@odata.bind": "Containers('OR:wt.pdmlink.PDMLinkProduct:64091')"
 post.addHeader( "Authorization", "Basic "+ encodedAuthorization);
 //post.addHeader("Accept", "application/json");
 post.addHeader("Content-Type", "application/json");
 post.addHeader("Accept","application/json");
 post.addHeader("CSRF_NONCE","ypTCuzcDl4rmuSC3jMyM71JH+8+sgGbbnN6j1lJp29rV90TG/ces9FtN38Kc4FTZiPr08k5g2rfciBWO+qT1ig43pbvSjhr5ruy41FV2/9uUzRTvha2t/XhVouSRhB0=");
 post.setEntity(params);
 HttpResponse response = client.execute(post);
 System.out.println("\nSending 'POST' request to URL : " + url);
 System.out.println("Post parameters : " + post.getEntity());
 System.out.println("Response Code : " + response.getStatusLine().getStatusCode());
 BufferedReader rd = new BufferedReader( new InputStreamReader(response.getEntity().getContent()));
 StringBuffer result = new StringBuffer();
 String line = "";
 while ((line = rd.readLine()) != null) {
 result.append(line);
 System.out.println(result.toString());
 Hicham
Hi
The CSRF-NONCE is provided by the REST API end point :
https://<Windchill server>/Windchill/servlet/odata/PTC/GetCSRFToken()
I'm not sure that the "MY-TOKEN" string had been provided by this end point  🙂
Hicham
VladiSlav17-PeridotAuthor
Thanks for the answer!
Yes, I copied my real token there, but I just decided to replace it so. 😅
I apologize for being misleading.
Here is the real tokens format that I am adding:
F4a464/MVN5bbrRdYtbXq+TnODYTPq9qbbHS2OOWM+xlT80oT7XgpumOIboWGtAvILbsnp18ZOHnR3FiI7CBxZn0dOZuDo3fIMTRne2lBpIJIt8qe6/ptv+fIREML4k=
hlafkir5-Regular MemberAnswer
 // add header
 "AssemblyMode": {
 "EndItem" : false,
 "DefaultUnit": {
 "Value": "ea",
 "Display": "Each"
 "Value": "0",
 "Source": {
 "Value": "make",
 "Display": "Make"
 String line = "";
 Hicham
