Automatic Constraints
- June 24, 2013
- 39 replies
- 15870 views
I've been having an issue since installing Creo 2.0 where I'm trying to create an assembly and pull in parts, but they're not constraining correctly. I was watching a Creo Primer video, and the speaker said that Creo is smart and will automatically learn the constraints you've been using on a part and will apply them the next time you pull the part in. My problem is that mine will not automatically learn the constraints, and I have to go back and re-select the parts and constrain them manually. This isn't a terrible issue, but it is annoying when the video says that something SHOULD happen and it doesn't. The first file that I put in for the assembly file was the cube and then started adding cubes and shafts (cube file isn't labeled as cube currently).
