Boundary blend failure with vertex
  • November 16, 2015
  • 2 replies
  • 2395 views
I am trying to create a boundary blend surface with two chains converging to a vertex point but it keeps failing and I'm not sure why.
I'm sure there aren't any open points in the chain loop.
For two of the chains, I used curve through points and ensured they both connected to the vertex point.
It informs me that the entities are tangent at the highlighted point and they should be made non-tangent. I made the curves free at the point and its still failing.
I have attached images of the boundary blend operation failing as PDF and a copy of the Creo model.
Sam
Sam,
Three sided boundary surfs are never easy.    If you look at the mesh you'll notice that all of the lines form a "cone" shape...   blending all that geometry down to a point makes it hard for Creo to do the math and it will often "wrinkle" the surface near the point. (and fail)  (especially a long taper like yours)
In this case,  I would recommend using your base curve (closest to the speaker circle) as the trajectory and using a "Swept Blend" feature "Normal to Projection" so that you can control the section sketches at each end.   Then Intersect-merge the surfaces together to create the outer tapered line.   You can then adjust your section shapes and angles to get the tapered line your looking for on the outer surface.   Hope this makes sense...
Looks like a fun little project!
Good Luck
Bernie
Bernie Gruman
Owner / Designer / Builder
www.GrumanCreations.com
Hello Sam
It would be easier to help if you upload STP model, instead of Creo Student Version file. I can`t open it neither I have student license.
Frankly speaking I would avoid appraoch you`re trying to accomplish this area.
Instead of trying to make 3 curves(3 sided) boundary surface, I would make 4 sided surface and trim it back,
Easiest way to make it is to use VSS too to create primary surface, then create Curve on this surface or project sketched one and trim it back.
please follow some of my tutorials which at the end should faciliate to you solving such issues in the future
https://drive.google.com/folderview?id=0B60eG4B19bE4VWpjaFlBNlZuMzg&usp=sharing
I encourage you to to check the one below
https://drive.google.com/file/d/0B60eG4B19bE4RTFtcVF0UU1ta0U/view?usp=sharing
