circle sketch over an existing hole
  • April 14, 2016
  • 2 replies
  • 4017 views
I can't figure out how to place a circle sketch over an existing hole, why can't it snap to the centers of the existing circles.
    Select the reference icon and then select the hole or the axis as a reference and it will constrain to the hole.
    not sure I follow you.  I new to this program
    The reference icon is here. It allows you to select geometry or datums to reference in your sketch.
    When you use a hole as a reference, if you move the hole, your sketch will move with it (depending on how you dimension it).
    This is from PTC's Tips and Tricks document - Please find the document attached to view their Tips and Tricks
    A Faster Way to Select References
    As you create geometry using the Sketcher tool, you
    may want your cursor to automatically snap to existing
    geometry (e.g., a reference) to more easily align
    components within your drawing.
    However, if you’re in the middle of using the Sketcher command, it’s
    too late to select a reference. You have to create your
    references before you start sketching. Alternatively,
    you can cancel the Sketcher tool, go to the upper left
    hand corner of your screen, use the Reference tool to
    specify the references, and then go back to using the
    Sketcher tool.
    With Creo 3 -
    The Alt key suspends the Sketcher tool, allowing
    you select your references as you work. As you
    sketch, simply hold down the Alt key and select your
    references. Releasing the Alt key instantly returns you
    to the Sketcher tool. You can now snap your cursor to
    the references you just selected. This tip applies to any
    version of PTC Creo Parametric.
