Copy geometry for beginner
  • July 15, 2016
  • 2398 views
How would you define copy geometry to an absolute beginner?
    Similar to Windows, or Firefox...
    Click "Publish Geometry" in Creo. Here you will define what you want to copy (like copying a Word text).
    Next in another part, click "Copy Geometry" in Creo, search the part, and click them. Then this is like the paste operation, because what you previously selected will be copied to your actual part.
    Did you get it?
    So if we do any changes to the original object, will the copied object undergo change as well?
    If the "copy geometry" isn*t set to independent (you can change between dependent and independent), then yes.
