Darwing Format question
Our drawing formats have a table for revisions created in the .frm .
The first row of the table has a cell text height of .12" and the
justifications are center middle with the exception of the "Description
of Change" which is left middle.
When I insert another row all cell heights default to a height of
.156250" with left justification (that's not even the default note
height in Pro).
Each cell has to be edited to the correct heights and justification.
Why does it not default to the existing upper row cell height? Can this
be corrected in the .frm?
Vinson A. Loos
Mechanical Engineering
DRS Tactical Systems - Melbourne, FL
(321) 727-3672 Ext. 3409
- <">mailto:->
www.drs.com <">http://www.drs.com>
NOTICE: This e-mail transmission (and/or the attachments accompanying it) may contain confidential or proprietary information belonging to DRS Technologies or the sender. The information is only for the use of the intended recipient. If you are not the intended recipient you are hereby notified that any disclosure, copying, distribution or the taking of any action in reliance on the contents of this information is strictly prohibited. Any unauthorized interception of this transmission is illegal under the law. If you have received this transmission in error, please promptly notify the sender by reply e-mail, and then destroy all copies of the transmission.
"This (document/presentation) may contain technical data as defined in the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10. Export of this material is restricted by the Arms Export Control Act (22 U.S.C. 2751 et seq.) and may not be exported to foreign persons without prior written approval from the U.S. Department of State."
height in Pro).
Vinson A. Loos
- <">mailto:->
