Drafting help needed..
  • June 6, 2013
  • 1877 views
Long time lurker, first time poster...
I have a drawing view consisting of a 60-hole bolt circle. I did a Show Model Annotation to display the centerline of the bolt circle, which includes the center line tick marks for each hole. I then edited the the bolt circle pattern to add an an additional 4-holes. The problem I'm having is I'm unable to get the center line tick marks for the new holes to show in the drawing view. I've regenerated the model, updated the views...I tried to show the axis for the new hole directly via the model tree, all to no avail. I can get them to show if I create a new view and show model annotations.
Please help.
Thanks!
Dale_Rosema
In the drawing, while your in annotation, right click on the pattern and go to show annotation.
Deselect all the dimensions (so they don't get added right now).
Go to the last (looks like a datum target).
Deselect all the centerlines.
Hover over the centerlines until you find the 4 that are missing.
Select them and the click OK
(WF5/Creo)
Hope this helps. Dale
RocketIII1-VisitorAuthor
That's the problem...there's nothing to hover over...they (the missing axes) aren't showing up.
