How to set default normal dimension to default basic dimensions in sketcher
  • September 21, 2015
  • 1596 views
How to set default normal dimension to default basic dimensions in sketcher.jpg
This is not possible with current functionality. You have to complete your sketch and then edit the properties on your dimensions to make the basic.
sdara1-VisitorAuthor
Thanks for the replay
Yeah, Right now I am following same process
Actually I have do for each dimensions (for every drawing we need to change more than
100
dimensions), so I working on for better process and time effective.
use Find button to select all dimensions. Then go to properties dialog and set Basic options for all of them in one step.
MH
