Line thickness when printing
  • December 20, 2012
  • 3 replies
  • 10574 views
When exporting a drawing to pdf for printing, some lines are coming out thicker than the others. My drawing looks exaclty like what I want in the drawing mode. I've tried using true type fonts and using stroke all fonts, but neither works. I may be missing something as I have just switched from WF4 to CREO 2.
Best answer by BrianMartin
Hi Jason...
Antonius is giving you good advice. You can tweak the line weights to achieve the look you want. I wrote a fairly long post explaining how it works and providing an example/starting file. The link below will take you to another thread where I gave this information:
http://communities.ptc.com/message/173301#173301
Scroll down a bit and you'll see one of my messages containing 3 attachments. One document explains how pen table files work. The other two are an example file and a cheat sheet showing you which pens draw certain elements of a drawing. Give these attachments a look. If they don't help and you're still having problems, please write back.
Thanks!
-Brian
My line weigths are doing pretty well with PDF options set to 600dpi. But I do give all my text a thickness of .012. I use the non-TTF and stroke all fonts in the options.
You can use pen tables to get the lines to come out heavier in PDF prints. I have not gone this far so I can't help but a search might find it in the discussions.
Hi Jason...
Thanks!
-Brian
Antonius & Brian....
Thank you for the quick responses. The pen table was exactly what i needed. I used the table that you supplied in the other post and it worked perfect.
Thanks!!!!!!!!!!!!
