mass of simp rep
  • January 2, 2012
  • 1192 views
Hi alls,
I've made some drawings of different simp rep of the same assembly.
In each case, I would like to write the mass of the simp rep assembly.
In each trails I've made, ProE display the total assembly mass, including
components that are not displayed.
Can someone tell me how to do, in a table or in a note ?
GB
To be able to show the Simplified Representation's mass in a drawing note, please follow the following steps (WF4.0)
1- Set the config.pro options "force_upd_assem_mp_in_simp_rep" to "yes" & "mass_property_calculate" to "automatic"
2- In the drawing set the wanted simplified representation as active using the menu #File #Properties> #Drawing Models> #Set/Add Rep> #Done.
3- Insert a Note for the assembly mass parameter the user defined or the system parameter (&pro_mp_mass:1)
4- Regenerate the model (#Edit> #Regenerate> #Model>#Automatic)
The note will always show the mass of the
