Productview - Highlighting parts
  • December 7, 2011
  • 5 replies
  • 2101 views
Hi all,
Iam using Productview Professional 9.1 M060.
When I browse the assembly structure after loading a PVZ , If I click on a sub assembly or part in the assembly tree, why the geometry in the graphics window is not highlighted (just like Pro/E)?
Also when I click on the geometry , why the part is not highlighted in the assembly tree?(just like Pro/E).
This drives me crazy, and do you guys have any solution , like a setting or preference?
Or is this a PTC "rule"?
Thanks in advance
Hari
could you check option > Navigation > highlighting > set to filled/ wireframe. This should enable you to over come the problem.
My settings are already as per what you told.
It works only when you click on a .prt in the tree, not for a .asm. (But Pro/E does for .asm also)
If you click on a part in the assembly structure its geometry, the geometry will not get highlighted. You have to expand the .asm tree and select all parts to get them highlighted.
On the other hand, when I click a geometry in model, iam not happy about the way in which the .prt or asm gets highlighted in the tree....I could barely see it highlighted in the tree because it is in a very very feeble color..How to change this to bold?
Hari
Yes,selecting assembly structure wouldnt highlight in the version that you are using. This is due the fact the sub-asm. do not contain an associated goem. file to visualise. This problemhave been resolved in Creo View 10. Similarly the visibility of the tree selection also improved.
I had mis-understood your original statement that the highlighting do not work when you select both .prt/ .asm from the tree.
I should open a "Enhancement request" to fix this "bug" for Product view 9.1... Correct?
Why cant they solve it in 9.1 itself?
wish I should have 'Like' button. 🙂
