Ref Balloon Radius
  • December 22, 2014
  • 3266 views
Greetings,
Does anyone know how to define the radius of the default reference balloon symbol?
For a standard balloon, it's rather simple; just use the "max_balloon_radius" or "min_balloon_radius" . This works great and allows for a uniform size. I'd like my ref balloons to be the same size, but I just cannot figure out how to do it!
Logically, one would think that the reference ballooons would follow these settings as well.
If not, it may just warrant opeing up a support case!
Looks like qty split balloons have a similar problem. These are both governed by the symbol rather than in internal operation.
I knew there were reasons I didn't like following the regimen of the automated process
The Balloon Note (my go to use-case) does follow the min/max regime. But I do have to manage my external qty references which can now be related to the balloon. I might just have to investigate a better way to use a balloon symbol so I can make it a little easier.
When the "max_balloon_radius" value is set to 0, the Ref balloon are the same size as the regular balloons.
