Creo View Screen Annotations
  • July 30, 2025
  • 385 views
I am having trouble with the scaling on flat-to-screen annotations when publishing a .pvz from Creo for viewing in Creo view. Previously I was using Creo parametric 7, and the flat-to-screen annotations would show up approximately the size in the screen window as I had it set in Creo.
After upgrading to Creo 10, the flat-to-screen annotations shrink and move on publishing. Is there a recipe file setting I can use to get them to scale properly?
Creo Parametric 10.0.8.0
Creo View 10.1
I am also having this exact same issue since upgraded into 10 (10.0.8.0). Did you figure this out at all?
