Attribute values from a DITA subjectscheme to the insert attributes drop-down list
Hello Adepters,
I'm going to use the new TIA application with Arbortext Editor 6.0 M040 for a project and want to provide enumerations of desired attribute values in the Insert Attribute dialog box.
For example, I'm going to use many values for the outputclass attribute to get the desired output. To make the authoring as intuative as possible we want to get the insert attribute dialog box loaded with our predifined attribute values for different elements.
I try to avoid touching the schema, even if I know it's an option in such cases.
Obviously, this could be done by defining keys in a Subjectsheme map.
Actually I saw a Youtube video demonstration about how this could be done with the Oxygen XML Editor, and I suppose it also must be possible to do with Arbortext Editor - but HOW? - I have surfed on the PTC Knowledge database, but haven't found an answer.
The Youtube video was at: (from about 15 minutes in the video to the end)
http://www.youtube.com/watch?v=MPt6wZ2wYig&feature=relmfu
So my question is:
How can I populate the Insert Attributes drop-down list with defined Attribute values from a DITA subjectscheme.
For example, enumeration of values to use for the outputclass attribute for the <ph> element.
Any suggestion about how to do this would be greatly appreciated!
Bjarne Melin
Freelance Document Architect
    Per the "DITA Standard Support" topic in the help center for Editor 6.0
    M050, the subject scheme feature of DITA 1.2 (referred to as "Controlled
    values and taxonomies") is not currently supported.
    However, Editor's profiling feature, which is available for any document
    type, provides much of the same functionality. I don't know if it will
    work with the outputclass attribute (haven't tried, myself), but you may
    want to use one of the standard DITA conditional processing attributes
    (audience, platform, product or otherprops), anyway. The outputclass
    attribute is, by design, intended as a sort of "escape hatch" when no other
    mechanism is suitable, ideally on a temporary basis pending a solution via
    specialization.
    The main limitation of profiling compared to a subject scheme, as far as I
    can see, is that profiling is configured globally for your document type,
    whereas you can use different subject schemes for each DITA map. If you
    have need for this kind of flexibility, you might consider creating one or
    more "skeleton" specializations that are really just plain DITA with
    different names, such that you can configure them differently. Your
    document type's DCF file points to a PCF file that configures the profiling
    feature, including labels and allowed values for each attribute.
    -Brandon 🙂
    Thank you Brandon for the answer!
    Good to know that Subject Scheme support isn't yet implemented in Arborbortext editor,
    so I have to choose another way to obtain the desired result. Using an 'authoring schema'
    that validates against the standard schema seemed to be the easiest solution for now.
    Afaik. using profiling and other settings in the DCF file can't be done so it only affects
    an attribute for a certain element. Instead it affects the behavior of the attribute on ALL
    elements with that attribute, and that is not what I want...
    ///Bjarne
    In Reply to Brandon Ibach:
    specialization.
    -Brandon 🙂
