Communication between Arbortext and Web application
  • January 16, 2013
  • 15 replies
  • 3916 views
Iam using Arbortext Editor 5.3 since last few months. I got a requirement to enhance User interface with more features (ex: Shuttle component).
I've developed sample UI application using ADF(Application Developement Framework) as per our client requirement and is running on Weblogic server.
I just want to provide communication from Arbortext to web application. I need to pass some information back to Arbortext from web application.
It would be really helpful, if you can suggest on this.
Is there any way to provide communication with other systems?
    18-Opal
    January 16, 2013
    Hi Sambasivarao--
    You could probably do this a couple of different ways:
    1) You can "open" XML documents using a URL, which would allow you
    to access many web services. If your web application can serve up the
    necessary data as XML in response to an HTTP request, you could use this
    to get web app data from Arbortext.
    2) If you need something lower level, ACL includes functions for
    opening TCP sockets for network communication. For example, search the
    Help Center for open_listen(), and you will see an example of a simple
    socket communications handler.
    HTH.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    1380 Forest Park Circle, Suite 100
    Lafayette, CO 80027
    I should also note that if you're using WebLogic, I'm guessing you're also
    using Java, which opens the door to native calls from jars put in the
    custom folder. We currently use AXIS to take advantage of WebServices
    hosted on a Microsoft platform, but going forward, I've started to convert
    many of these to simpler JSON calls. The best part is there are plenty
    of JSON libraries available for Java to save you from having to do any
    manual parsing of web calls.
    - keith
    Thank you.
    I can publish an event from our web application on button click. But not sure, how Arbortext can subscribe to the event and then act on that.
    Our application is running on weblogic server & Arbortext is stand alone. How can we synchronize these two?
    Could youplease provide more details on this?
    -Samba.
    Hmm, well typically, web applications work in reverse, where Arbortext
    would make the call and get a response. However, if you're on the same
    machine, it might be possible to just reference the aom.jar directly from
    your webapp. (Located in lib/classes)
    What do you plan to do with this topic ID once in Arbortext? I ask,
    because working in reverse like this makes some assumptions that Arbortext
    is running, a document is open and there's a valid location to place the
    value. On the flip side, having a XUI button in Arbortext, say "Get Topic
    ID", could instead invoke a call to your web app and retrieve the value
    on-demand.
    keith
    On Thu, Jan 17, 2013 at 3:53 AM, SAMBASIVARAO MEDAVARAPU <
    sambasivarao.medavarapu@oracle.com> wrote:
    > Thank you.
    > Could you please provide more details on this?
    > -Samba.
    Here's an idea.
    1. Have your web application publish events as an RSS feed.
    2. Write an Arbortext custom application which subscribes to the RSS feed.
    3. In Arbortext, Java or Javascript, check the RSS feed for updates on system start or on user menu or toolbar click. Any event you find in the RSS feed which you haven't already processed you then action.
    You didn't describe what you're trying to do with these events, but the other option is that you are trying to trigger a workflow process based on the fact that a new event has been published. In that case, the workflow tool (not Arbortext) should pickup the event and make a task for an Arbortext user to work on. The RSS idea might still work in that scenario too.
    -G
    18-Opal
    January 18, 2013
    Actually, another idea just occurred to me: Arbortext supports a custom
    HTTP protocol for launching a document. Search in the Help Center for
    "integrating arbortext editor" and read the topic "Integrating Arbortext
    Editor with web pages".
    Your web application may be able to do something like this (via
    JavaScript):
    window.open("arbortext-editor:C%3A%5Csome%5Cpath%5C" + topicID +
    ".xml");
    Note that the path to the topic (the part after the colon) should be URL
    encoded.
    Hopefully that will be an easier way to fire Arbortext from your web
    application without having to define listeners, RSS feeds, etc.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Lafayette, CO 80027
    Found few results with Search in the Help Center for "integrating
    arbortext editor". But could not find a topic as you referenced i.e
    "Integrating Arbortext Editor with web pages".
    I am using Arbortext Editor *5.3*. Is it because of version difference?
    Please suggest version to be referenced.
    I've a doubt on "arbortext-editor:" keyword used in window.open command.
    Not sure, How our web application identifies the key word? But I didn't
    tested this option so far 🙂
    -Samba.
    18-Opal
    January 18, 2013
    Those protocols are only available with version 5.4 or 6.0. If you have
    to stick with version 5.3 for some reason, you will probably have to go
    the port listener route or something similar.
    If you can upgrade to a newer version that supports the protocol, then
    your web application doesn't need to know anything special about it. It
    is configured on the clients where Arbortext is installed. Arbortext
    Editor registers itself as the default handler for the
    "arbortext-editor" protocol, so client browsers should be able to do the
    right thing with a link of the form
    "arbortext-editor:some-url-encoded-path-to-xml-document". Note that the
    path can be either a local file reference, as in my original example, or
    an http link to a webdav server object.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Lafayette, CO 80027
    Hi Clay,
    We are planning to create proof of concept by using Arbortext 6.0. We
    have already 5.3 installed in our local. I got trail version of 6.0. Can
    I have two versions at a time?
    I don't want to disturb the existing one i.e 5.3. Can you suggest on
    this. BTW, there two flavors of 32bit & 64 bit Arbortext 6.0. Which is
    the best option to test our usecase
    Samba.
    We run two versions at one time. We typically modify the install path to
    include the major version number. For example, we will install into:
    c:\program files\arbortext\editor53
    You may want to match your Java environment. Our "Enterprise Windows 7
    Image" provisioned to each workstation/laptop is 32bit and out of our
    control. We had to change our initial deployment from the 64bit Editor to
    the 32bit in order to avoid a number of issues that started popping up. I
    can't remember which modules complained, though, it might not have been
    core functionality. Documentum integration, perhaps?
    On Thu, Jan 24, 2013 at 6:08 AM, SAMBASIVARAO MEDAVARAPU <
    > Hi Clay,
    > We are planning to create proof of concept by using Arbortext 6.0. We have
    > already 5.3 installed in our local. I got trail version of 6.0. Can I have
    > I don't want to disturb the existing one i.e 5.3. Can you suggest on this.
    > BTW, there two flavors of 32bit & 64 bit Arbortext 6.0. Which is the best
    > Thanks,
    > Samba.
