FOSI approach vs XSLT
I've been doing lots of work in XSLT/FO but I'm having to switch gears and
work on a FOSI.
I'm in the XSLT/XPATH mindset and I know there are similar capabilities,
but I'm wondering if the approaches to problems would be different. The
I'm currently considering is transformation, specifically moving large
sections around. So I have a rear section that can contain appendices,
list of effective pages, index, etc. In my DTD I want to set a specific
order and repeatability on these objects. So I have the following:
* appendix
? index
? lep
well some groups might want the lep in front of the index. With XSLT I
would just choose to process the lep before the index and I wouldn't
change the physical order in the content. FOSIs I've seen in the past seem
to just process things in place in terms of large objects. They generate
text and such but I don't think I've seen much reorganization of the
content.
Is this a limitation of FOSIs or just the [programming style of the writer?
..dan
    On Thu, May 20, 2010 at 7:37 PM, Paul Nagai <-> wrote:
    >> The key to success with FOSI is to think in terms of context and
    >> occurrence. Procedural thinking usually does not apply.
    > I sense a PTC/User 2011 Panel: FOSI vs. XSL(/FO). Come up with some prepared
    > "problems" and show the strength and weaknesses of each technology and then
    > take problems from the audience Smiley Wink
    Hey, Paul...
    There might be more to that winking smiley than first appears, but
    just in case, have you checked out the Arbortext agenda for PTC/User
    2010?
    > Extra points if we can come up with a session title including the word
    > "Shoot-Out"!
    Actually, we had to settle for "Shootout" when our other panelist
    couldn't figure out how to work in "Thundah Down Undah". Smiley Wink
    -Brandon Smiley Happy
    LOL! There are a couple of touch-points on that thing. That agenda must have
    snuck into my subconscious.
    On Thu, May 20, 2010 at 4:53 PM, Brandon Ibach <
    brandon.ibach@single-sourcing.com> wrote:
    I haven't had nearly as much practice with this stuff as Suzanne, so maybe I'm wrong; but I always thought that XSL/XSLT was pretty fast, but adding the "-FO" to the end of "XSL" was what slowed thing down significantly. Like I said, maybe I'm wrong
    I was going to suggest pseudo-attributes as well. I try to avoid them
    if I can (they require you to put a special PI into your XML DTD and
    compile them like SGML DTDs), but they do serve a useful purpose.
    Another suggestion (and a method I use to generate most LEP and TOC
    content) is using the userule of a usetext to write out aggregated
    content to external files. Then you can use ACL/Perl/XSLT to tape
    documents back together in any order you want. A nice feature is this
    provides you the ability to read in SGML documents and create XML output
    from them (which if you have a lot of inclusions/exclusions and other
    SGML-only constructs can come in really handy).
    For allowing authors to drive some of the content/formatting decisions
    without letting them near the stylesheets, using ACL with system-func
    attribute rules are pretty useful. Just use them sparingly. I've seen,
    under certain conditions, these cause the system-crippling effect that
    Paul has mentioned before.
    -Jason
    18-Opal
    May 21, 2010
    Hi Ed-
    You're at least partially right. The XSL transformation itself can be
    very fast or very slow, depending on how involved the transformation is
    and how well you've coded your stylesheet. There are many ways to code
    an XSLT stylesheet badly, so I think this has given it a somewhat
    exaggerated reputation for slowness. In many cases, when an XSL
    transformation is slow, it's not because of the process per se, but
    rather because the stylesheet author inadvertently chose an inefficient
    method to accomplish their goal. I once worked on a stylesheet that was
    taking about an hour to process a document; with a few simple XPath
    changes, I was able to make it do the same job in a few minutes.
    As for adding the -FO, that does add some extra layers to the publishing
    process, especially with Arbortext. In Arbortext, XSL-FO publishing goes
    something like this:
    1) The source XML is transformed to XSL-FO markup via XSLT
    stylesheet
    2) Arbortext does some post-processing to propagate inherited
    properties and other "cleanup" tasks it needs for the next step
    3) The XSL-FO instance is published using a special FOSI stylesheet
    designed for the XSL-FO doctype
    So, you can see, XSL-FO publishing will generally take at least as long
    as standard FOSI publishing because of step 3, plus whatever time is
    required for steps 1 & 2. Step 1 can be demanding, because the
    transformation to XSL-FO has to transform pretty much every element in
    the document into something else in the XSL-FO vocabulary. Even so, with
    careful coding it can be made reasonably efficient.
    Whether or not the time difference between XSL-FO and FOSI is
    significant or prohibitive will depend on the specific situation, i.e.
    how large the documents are, how complex the transformations are, and
    how efficient the XSLT stylesheet is.
    --Clay
    Is that in an Arbortext environment only?
    Based upon Clay's statements and some of Suzanne's it looks like they run
    FO out to FOSI before doing any work. I've only used this stuff outside
    Arbortext with products like Apache FO, RenderX and Antenna House and have
    not had any serious problems. Now I wasn't running massive jobs or large
    volumes on a daily basis so it wasn't a problem I needed to find a
    solution for. If you already have the Print Composer maybe FOSI is the
    most efficient way to go, but it is expensive both as a product and the
    fact that there aren't many who know the language and in some cases don't
    want to learn it. So your cost is not just in the runtime environment.
    It is a different world where XSLT/FO are being taught and used in school,
    so now you have trained bodies available. Also you can get a free soultion
    in Apache and not too expensive in RenderX/Antenna House.
    I have to deal with FOSIs primarily becasue I'm doing defense work and
    that is the standard. But even there I was doing some NAVSEA work and they
    have switched over to Contenta and their proprietary formatting language.
    From an Arbortext standpoint it doesn't bode well when Styler is not able
    to ingest a working FOSI and let people switch back and forth easily. So
    if you have one or more legacy FOSIs around you can't even get them into a
    tool that novice users might be willing to use. FOSIs are just this weird
    animal that we have to deal with.
    ..dan
    Efficiency is one of the problems I see with XSL and, for that matter, DSSSL. Of the many ways to code an XSL or DSSSL stylesheet that produces the desired output, most will not be optimal. Coming from a production background, that spells trouble to me, especially since I know from my consulting experience that not every developer is a careful coder.
    There are also many ways to code a FOSI. You can use charsubsets and/or environments and/or direct coding -- but that affects only(!) ease of development and maintenance, not run-time, because FOSi is compiled. Optimization is a product issue, not an issue for the FOSI developer. It is true that too many attribute rules and/or system-funcs can cripple FOSI performance, but that's about it. Otherwise, FOSI runs as fast as the content permits.
    Sounds like the makings of a drinking game for a late night at PTC/User!
    And definitely a topic for discussion at the TC.
    On Fri, May 21, 2010 at 9:55 AM, Suzanne Napoleon <
    > content permits.
    I agree FOSI is a weird animal. (makes me wonder what animal O'Reilly would pick for a book on FOSI) FOSI is a declarative language that describes the problem and leaves the solution to the interpreting software. This is naturally disruptive to anyone accustomed to procedural and functional languages. The trick is to stop thinking about telling the software what to do. Instead, tell it what it wants to know where it wants to know it. The software does the rest. Hmmm . . . maybe the analogy is moving from the pilot's seat to the navigator's seat . . .
    18-Opal
    May 22, 2010
    Hi Suzanne-
    Interesting. I have to admit, when you say "the developer doesn't have
    to be a computer scientist to be able to develop an easy-to-maintain
    FOSI", it makes me think of the brilliant math professor who presents a
    subtle and complex proof and claims "It's intuitively obvious!" To the
    professor, it probably is; to the students, not so much.... 🙂
    I wonder if FOSI seems easy to you simply because you have such enormous
    depth of knowledge and experience with it. I can't speak for anyone
    else, but I myself don't find anything about FOSI stylesheets to be
    especially easy. This is exacerbated by the fact that information about
    FOSI is so hard to come by-which is why we're all so eager for your book
    to be done.
    There is probably something to the argument that FOSI lets you get the
    most out of Arbortext. OTOH, to develop the level of skill necessary to
    do some of the things you mention as examples, I think you would have to
    spend a good bit of time specializing in FOSI development. In that
    sense, you would be just about as specialized as the average "computer
    scientist", albeit in a different kind of technology.
    --Clay
