Modifying a selected range of text
I'm trying to write an ACL script in 5.2 that will take a user selected
range of elements. In this case a series of step1 elements, take that
selection, delete and turn it into a seqlist with items. I can run the
following sample code at the command line and I get what I'm expecting:
copy_mark buf1;
delete_mark buf1;
response(oid_name(oid_first(buffer_doc(buf1))));
response(oid_content(oid_first(buffer_doc(buf1))));
paste buf1;
BUT when I put this in a file, create a funtion and assign it to the F12
key, the response messages show no content, the delete doesn't work but
the paste does. Any ideas on what is going on?
function step1_to_seqlist() {
copy_mark buf1;
delete_mark buf1;
paste buf1;
response("loaded");
map f12 step1_to_seqlist();
    18-Opal
    May 6, 2010
    Hi Dan--
    When using commands in a function, you need to be careful to put quotes
    around literals like names. On the command line you can get away with
    this:
    copy_mark buf1
    and Arbortext will figure out that you mean "buf1" to be the name of a
    buffer. But in a function defined in an ACL file, you need to put quotes
    around the buffer name so Arbortext knows you mean a literal name and
    not a variable reference. So it should look something like this:
    copy_mark "buf1"
    This applies to all the references to the buffer in the function.
    Also, w.r.t. the delete not working, you might need to add the -noclm
    flag to the copy_mark command to prevent it from clearing the selection
    after the copy. (Caveat: I'm using 5.3, so it's possible that 5.2 is
    different, but I would be surprised.)
    copy_mark -noclm "buf1"
    So, in total, here's what works for me:
    function testpaste() {
    local buf1;
    copy_mark -noclm "buf1";
    delete_mark "buf1";
    response(oid_name(oid_first(buffer_doc("buf1"))));
    response(oid_content(oid_first(buffer_doc("buf1"))));
    paste "buf1";
    HTH
    --Clay
    I guess this quoting and non-quoting reflects the way the
    documentation/help is setup. got to be careful about which help on a
    function that you read.
    The quotes fixed the problem as well as the -noclm. I read the -noclm as
    not "deleting" when it said not clearing.
    ..dan
    > Hi Dan--
    > this:
    > copy_mark buf1
    > copy_mark "buf1"
    > local buf1;
    > delete_mark "buf1";
    > paste "buf1";
    > HTH
    > --Clay
