Passing list of params from Java to ACL
Hi adepters,
I'm trying to pass off a list of parameters from java to an acl function. The acl function expects the list of params like so:
function myFunction(filename, params[]) {
if(define (params["Param1"]) {
# do something
My java method call looks like this:
Acl.func("myAcl::myFunction",filename);
I'm a beginner/novice with Acl, so I don't understand how to pass off the params. Here's some of my ideas but I haven't tried the right variation yet that works:
Acl.func("myAcl::myFunction",filename,"Param1=MyValue,Param2=MyValue");
Acl.func("myAcl::myFunction",filename, "-Param1 MyValue", "-Param2 MyValue");
Acl.func("myAcl::myFunction",filename, "Param1('MyValue'), Param2('MyValue')");
Acl.func("myAcl::myFunction",filename, "MyValue", "MyValue");
Thanks in advance!
    18-Opal
    March 21, 2012
    Hi Kristian--
    You could rewrite myFunction to take the list of params as a delimited
    string (somewhat like what you tried in your first "Acl.func" call). You
    would then have to convert the delimited list to the desired array in
    the function. It would look something like this:
    function myFunction(filename, paramlist) {
    # split up params into proper array
    local param_entries[], params[], tokens[];
    split(paramlist, param_entries, ",");
    for (p in param_entries) {
    split(param_entries[p],tokens,"=");
    params[tokens[1]] = tokens[2];
    # now do whatever you want with params array
    If you are pulling the array from ACL (as opposed to pushing it from
    Java), you can use the java_array_to_acl() function to convert a Java
    array (or Map or List) to the corresponding ACL object. For example, if
    you have a java method DOMhandler.getAllElements() that returns an
    array, you can convert it to ACL by doing something like this (in ACL):
    function checkElements(doc) {
    # create Java object, equivalent to "new DOMhandler(doc)"
    local handler = java_constructor("DOMhandler", Acl.DOMDocument(doc));
    # call getAllElements method and store reference to the Java array it
    returns
    local jarray = java_instance(handler, "getAllElements");
    # convert Java array to ACL array
    local aclarray[];
    java_array_to_acl(jarray, aclarray);
    Also, there is a discussion of Java and ACL arrays in the online help
    topic "Java and ACL". Type "help 1381" on the command line in Arbortext
    to see this topic.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
