XPATH question (again)
Here's my structure (Styler 5.4):
<condtinsp>
<inspection>
<condition></condition>
<req></req>
</inspection><inspection>
<req></req>
<req></req>
</condtinsp>
I want to number the condition tags but only if they have content (they have no title so making them a Formal Block didn't help) with the XPATH count(../preceding::condition) + 1
I created a content test condition for the XPATH on <condition> in Styler so only the non-empty conditions are numbered, but the counter is incrementing on the empty conditions. So the first three numbered <condition>s are numbered 1, 9, 10 because there are 8 empty conditions following the first numbered one.
I don't know how to keep the empty <conditions> from incrementing the counter, or if that is even possible. Some kind of subtraction, maybe?
Thanks for any ideas!
    Using FOSI terminology, this might work:
    You could put a savetext with a conrule (construction rule) of #CONTENT in the e-i-c (element-in-context) for <condition>.
    Then you could have an attribute rule to check if this savetext had a value of #ANY and then increment the counter.
    Assuming that your structure is consistent and the <condition> element is always a child of <inspection>, you would need to reset this savetext to be equal to "\\" (null or empty in FOSI talk) in the e-i-c for <inspection>.
    18-Opal
    May 17, 2012
    Hi Caroline--
    You probably want something like this:
    count(../preceding-sibling::condition[not(* | text())])+ 1
    HTH.
    --Clay
    Clay Helberg
    Senior Consultant
    TerraXML
    Your XPath counts all preceding conditions, but you only want to count the
    ones that have a child node, so try something like
    "count(preceding::condition[node()]) + 1". If you have "empty" conditions
    that get counted because of some whitespace inside of them, try
    "count(preceding::condition[* or normalize-space(.)]) + 1".
    -Brandon 🙂
    On Thu, May 17, 2012 at 3:35 AM, Caroline Leccese <
    > <condtinsp>
    > <inspection>
    > <req></req>
    > <req></req>
    > <req></req>
    > </condtinsp>
    18-Opal
    May 17, 2012
    Oops, I got it backward, that one will count only the conditions you
    *don't* want. Here's the right version:
    count(../preceding-sibling::condition[boolean(* | text())])+ 1
    Clay Helberg
    Senior Consultant
    TerraXML
    cleccese1-VisitorAuthor
    Thank you everyone! Brandon's worked.
    Although this morning I realized I could simply increment and output a counter in FOSI in the non-empty content condition I had set up for <condition> in Styler:
    <enumerat increm="1" enumid="conditionct"/">
    <usetext source="conditionct,\.\,@10pt" placemnt="before"></usetext>
    I should have figured this out before posting but I do keep all the responses to my XPATH questions in a file which I refer back to constantly, so I appreciate everyone's help.
    Whoops! <condition> has to reset when it hits<syshd>
    <inspection>
    <req></req>
    </inspection>
    <inspection>
    <req></req>
    </inspection>
    <inspection>
    <req></req>
    </inspection>
    <syshd></syshd>
    <inspection>
    <req></req>
    </inspection>
    <syshd></syshd>
    <inspection>
    <req></req>
    </inspection>
    Thanks to Brandon's response to another thread, I figured it out to be:
    count(preceding::condition[node()]) - count(preceding::syshd[1]/preceding::condition[node()]) + 1
