Dec 8, 2016 6:02 AM UTC
A Basic Question : Why regeneration required in Creo?
Dear all,
There are lots of CAD softwares in market. As per my knowledge, I couldn't find any such regeneration happening in any other CAD tool.
Please share information regarding regeneration in creo
Sandeep
    KenFarley
    KenFarleyAnswer
    Dec 8, 2016 11:56 AM UTC
    What are these other "CAD tools" of which you speak? Doing a cursory search I find regeneration used in two of the prime competitors to Creo, NX6 and SolidWorks. Perhaps you are comparing a non-feature based modeling program to this one?
    Here's an example of a situation where regeneration is welcome: You're working on a horrible model that has upwards of 800 features in it. You want to make some small changes to three or four dimensions, nothing major, just slight adjustments. Presumably, if regeneration didn't exist, your model would have to update automatically each time you made a change to one of the dimensions. So, you'd be forced to sit through a series of lengthy recalculations and updates. And, if you weren't careful in the order of the changes you made, you could also suffer the nightmare of a failure. It's much better to be able to modify all of the dimensions necessary, then just sit through one regeneration. This isn't a hypothetical case, either, I've had run-ins with this type of thing before.
    In "olden times", as I recall, the models we created were "dumb" models, in the sense that you had the final geometry, but didn't have all the intermediate stages available to you. If you wanted to "fix" a feature, you couldn't roll back the model and change the operations that created it. You had to patch up your model in some clunky manner and then do some more work to get the correct end result. Good stuff for concocting horror stories, but not for getting things done efficiently.
    Dec 8, 2016 9:21 AM UTC
    Please do not cross-posts: A Basic Question : Why regeneration required in Creo?
    KenFarley
    KenFarley21-Topaz IIAnswer
    HamsterNL
    18-Opal
    Jan 21, 2017 7:06 AM UTC
    ...and also in Autodesk Inventor
    Patriot_1776
    Dec 9, 2016 4:48 PM UTC
    ....and on the related subject of "Why Is There Air?".......
    Dec 10, 2016 3:44 AM UTC
    When you don't want to answer, keep quite. There are many doubts on this community which use to come from new learners. That may be very basic or silly. But yet experts give a related answers. If you want to make jokes on others try it on other social media. If you know everything about creo, give anwers to all query's on this community.
    2-Explorer
    Dec 10, 2016 6:22 AM UTC
    It is also polite to recognize that many experts have already given answers and that you can select "Like" to indicate you appreciate the effort.
    (also - doubt = feeling uncertain or disbelief. "Question," as a noun, means to ask for information.
    I doubt the sun is orange. The teacher asked a question)
